code 0520
Old Mar 24, 2009 | 02:48 AM
drywallguy's Avatar
drywallguy
Default code 0520
can anyone please help me with this code,im trying to zero down what this could be.oil pressure sensor? 0520.
Old Mar 24, 2009 | 05:22 PM
65standard's Avatar
65standard
that would be correct
Old Mar 25, 2009 | 01:11 AM
drywallguy's Avatar
drywallguy
thanks for the quick reply.where would the oil pressure sensor be located? it is not unusual for them to go bad?
Old Mar 25, 2009 | 07:52 PM
65standard's Avatar
65standard
i guess i could look it up if i knew what engine you have.
Old Mar 25, 2009 | 11:17 PM
drywallguy's Avatar
drywallguy
hemi. thanks.
Old Mar 26, 2009 | 07:24 PM
65standard's Avatar
65standard
the oil pressure sensor is located in the lower front of the block, behind the alternator. you have to remove the alternator to get to it. the part number is #05149062AA. dodge later changed the part number to #56044777AA. they are the same part with different numbers.
carefull not to confuse this pressure sensor with the oil temp sensor. good luck with it.
Old Mar 27, 2009 | 01:02 AM
drywallguy's Avatar
drywallguy
thanks alot for your help.
