Removing the Head Unit
Old Mar 15, 2005 | 04:08 PM
xdreamteam420's Avatar
xdreamteam420
Default Removing the Head Unit
I just recently ordered a kenwood ddx7015 I was wondering how to take off the dash to get to the radio. Is there any screws or is it snap off. I Also have a dash kit would it ruin the dash kit. If some could help me out it would be great. Thank you
Old Mar 15, 2005 | 04:14 PM
Angry Pickle's Avatar
Angry Pickle
Default RE: Removing the Head Unit
thinking back in my memory, it's snap on.
I remove the ash tray then pull out on the bottom. I can then get my fingers on the sides and pull straight out. You have to be carefull with the wires leading to the a/c and the buttons up top. They can be a bit tricky to get. You squeeze them which releases the lock then pull out.
-Dave
Old Mar 15, 2005 | 04:18 PM
xdreamteam420
Thank you and i have one more quetion. Are all the cables for dodges the same. You know the one that will connect the new head unit to the wiring of the old head unit.
Old Mar 24, 2005 | 07:03 PM
356MAGNUM's Avatar
356MAGNUM
I used the mounting and wiring listed for an '04 Durango. And it all fits perfect. Except for fact that there is no switched power lead at the radio harness of the Magnum.
Old Mar 26, 2005 | 02:29 AM
undropped's Avatar
undropped
i but the JVC in mine, as for switched power you can tap off the lighter right below it, also mine didn't have a illumanation wire. However I found one in a unused harness that was part of the switch for the hazard lights between the upper air vents. Just take a voltmeter and start probeing. For those of worried about using the lighter for power uncan use it to trigger a relay.
Old Mar 26, 2005 | 03:07 PM
356MAGNUM's Avatar
356MAGNUM
Roger that, I did the same thing with the Power outlet. I guess I should have said that too.
