A/C
Old Apr 2, 2005 | 11:36 PM
xdreamteam420's Avatar
xdreamteam420
Default A/C
Does anyone have any problems with their air conditioning. I was on a 5 hour drive and it was about 90 degrees outside, My A/C stoped blowing cold air. It went back to normal blowing cold air after the trip. I was wondering if anyone has had this problem.
Old Apr 3, 2005 | 04:25 AM
MikeyB's Avatar
MikeyB
Default RE: A/C
Sounds like the evaporator froze up. If the system is low on freon this can happen. I would go to the dealer and have the system checked.
MikeyB
Old Apr 3, 2005 | 12:59 PM
MagnumRT's Avatar
MagnumRT
Default RE: A/C
Sounds like something frooze up, did you have temperature set too low?
Bob
Old Apr 4, 2005 | 05:23 PM
magnumb's Avatar
magnumb
Default RE: A/C
I had this problem also. Only on longer trips. I'm not sure what they did, but the dealer fixed it. You should be able to keep the air as cool as you like...
James
Old Apr 5, 2005 | 02:59 AM
JETNBYA's Avatar
JETNBYA
Default RE: A/C
This has happened to me twice. Dealer was unable to duplicate the problem. But, as soon as I shut the car off. Then turned it back on, cold air was blowing. In both cases, my air was on for less than three hours and temps were not that extreme.
Jim
