Magnum Strut Replacement
I have a 2005 Magnum R/T and am planning on replacing the struts. What is the best spring compressor or method to compress the springs to use. I have a couple of spring compressors, but it appears there is not enough clearance to use them, mainly between the coil spring and upper control arm.
Thanks in advance.
Joe
Thanks in advance.
Joe
