New dodge magnum hood, any thoughts
Old Jun 6, 2005 | 02:28 PM
  #31
65standard's Avatar
65standard
Default RE: New dodge magnum hood, any thoughts
don't put the scoop over the stock airbox. keep the scoop front and center and move the airbox over the radiator. this would eliminate all those 90 degree turns. seal the airbox tight to the hood. use a airbox like this.
the late 90's trans-am had the ideal setup.
[IMG]local://upfiles/13006/B52A4DB0DB4F46D1A362C491EAF768A2.jpg[/IMG]
Old Jun 6, 2005 | 11:04 PM
  #32
vyvian's Avatar
vyvian
i just want to force air the cold air in. the viper hood moves the air over a hot motor. i think the way i want would be more effective. at least i hope. moving the air filter is an idea i will now entertain. i'm a pretty broke guy and will be doing all this work myself. maybe using a WRX STI scoop straight into the aforementioned trans-am aircleaner would work. but i gotta think about when i get the supercharger will there be space. any more ideas?
[22 years old, '05 silver magnum r/t]
Old Jun 7, 2005 | 07:12 AM
  #33
Diamondrmp's Avatar
Diamondrmp
A forum member on another forum has this hood go through R&D now. Check out the thread.
http://www.dodgetalk.com/forums/showthread.php?t=46137
Old Jun 7, 2005 | 09:51 AM
  #34
vyvian's Avatar
vyvian
does anyone know if that hood is availible? and if i went with the idea to move the air box, how would this effect the airflow sensor?
Old Jun 7, 2005 | 10:44 AM
  #35
Diamondrmp's Avatar
Diamondrmp
ORIGINAL: vyvian
Which hood are you talking about?
Old Jun 8, 2005 | 04:13 AM
  #36
vyvian's Avatar
vyvian
the hood from another thread. its called the magnum force. is that hood available yet?
and does anyone know if there would be problems w/ the air flow sensor if i moved the air filter to center on the radiator.
Old Jun 8, 2005 | 07:41 AM
  #37
Diamondrmp's Avatar
Diamondrmp
ORIGINAL: vyvian
The hood is designed by Forum Member "Magnum Force and that is the name he gave the hood. It is not out yet but when it is he said there will be a group purchase offered to all of us.
Old Jan 26, 2007 | 01:29 PM
  #38
doogie48084's Avatar
doogie48084
so is it available yet?
