Removing Front Door Panels on Magnum SE?
Old May 5, 2005 | 12:21 AM
theoppositeofsuicide's Avatar
Default Removing Front Door Panels on Magnum SE?
Just wondering if anybody knew the easiset way to remove the door panels on the front doors of the Magnum SE. Want to put some new speakers in. Instructions or Diagrams would be greatly appreciated.
Old May 6, 2005 | 01:54 AM
2005 Magnum R/T Hemi's Avatar
Default RE: Removing Front Door Panels on Magnum SE?
The Opposite of Suicide,
Nope, sorry...
[sm=headbang.gif]
Old May 6, 2005 | 12:21 PM
Pentagon Magnum's Avatar
Pentagon Magnum
That may work...bang your head against the door panels. Eventually something will give (either your head or your door panel- may be a good test)[sm=signs003.gif]
Old May 7, 2005 | 05:07 AM
dodgemech's Avatar
dodgemech
Very tricky, those little retainers all the way around the panel actually need to pushed INTO the door panel. Try not to push them all the way through (they are a bitch to find inside the door). Make sure you have removed all the screws (3 I think) and pull it off.
Old May 7, 2005 | 01:12 PM
MAGNUM8R's Avatar
MAGNUM8R
I saw my tint guys do it an about 30 secinds per panel, pull the screws, and carefully pop the snaps. It was amazing, I would have spent all morning doing this!!
Old May 7, 2005 | 01:39 PM
356MAGNUM's Avatar
356MAGNUM
I used the key to push in the center. It is the perfect depth. If you do loose the center or break one, they are under a buch each. $.63 if i remember right!
