Need Help Bad!!
So my friend wanted to put a remote start into his magnum, so we get it all hooked up and he bought the wrong bypass module, so we got the right one and its still not starting up and staying running. It starts up for about 10 seconds and shuts off, I have all the wires hooked up where they need to go, the only ones I dont have hooked up are wires called ftcan hi and low, which I found out go to the SKREEM module. Which would make sense as to why not it was not staying running, because the bypass is suppose to bypass the sentry key. So what I need to know is which wires to tap into on the SKREEM module to make this work? Or if somebody has a wiring digram for the connector on the SKREEM module? If somebody could help me out shortly that would be wonderful, as im working on it now! Thanks in advance ya'll!
I could really use some help if anybody can help me out, the remote start is really kicking me in the head, Its been almost a month working on and I cant figure it out. I really would like some help from all of the dodge owners!
on top of the 2 can wire, Is there another wire coming out of the By-pass module and tape around the Skim Module Ring around the Lock Cylinder? I've seen a lot of aftermarket remote start has them. Because the Ring Antenna is what pick up the Secret code from the By-Pass module or Key.
it starts and die because the Skreem module is unable to identify the key.
The Can wires are there for different reason i believe.
I have no experience with aftermarket remote start installation, but I've worked on a lot of cars with remote start, there i seen wires being taped around the skreem ring.
That was the first one my friend bought and it didnt work and the guy said he bought the wrong one. So he bought an xpresskit xk09 bypass, and it still didnt work, and i called up xpresskit to figure it out and they told me to hook up the tach which i did, therefor i called them again a few weeks later and they said that they have had many complants about bulldog security remote starts. Has anybody ever put one on, or have one?
