ABS and BAS light on
Old Jun 2, 2011 | 09:02 AM
mballard34's Avatar
mballard34
Default ABS and BAS light on
Hi All
got a little new problem with my car, magnum 07 rear traction SXT
My ABS and BAS light goes on when i start the car
also when i ride on and off to finally stay on
the first 5 min ride i get a grinding noise when i apply the brake
then the noise goes away.
*Also the cruise control is not working anymore...
Somebody as a clue what part is defective and where it's located.
Thanks a lot
Mike
Old Jun 4, 2011 | 03:24 PM
steak59's Avatar
steak59
Does Horn, Wiper blades, turn signals work ok?
Maybe Steering Coloumn Module is dead or blown fuse. Check All fuses.
brake Grinding wise, you'll have to do a brake inspection.
If everything else works except what u mentioned, You might have to scan for Code instead of just guessing.
I believe when ABS has problem, Cruise Control Function will be disabled.
Old Jun 5, 2011 | 12:49 PM
mballard34's Avatar
mballard34
All work goes except the cruise control
and the abs esp light
i have remove both alloy plate in the front, those that protect the brake from dust they where broken and loose; i have remove the right one 1 month ago then the same day the problem abs happen maybe i have damage the right sensor ?
the brakes are new! but i have to change the front rotor
is there anyway i can disable the abs system, i have 4 wheels sensor
i do see 2 sensor wire getting into one plug (block) in the center of the car at the rear wheel.
i don't have the $$ right now to get it fix garage and scan are lot $$
thank you
Mike
Old Jun 5, 2011 | 06:10 PM
steak59's Avatar
steak59
You probably torn the sensor when u are working on it. Inspect the Sensor wire, check for cuts. Or maybe something else torn it off since u removed that shield.
With those lights ON, ur ABS is alrdy disabled. your car is still safe to drive.
