engine vibration
Old Nov 11, 2011 | 09:54 PM
dubs'se's Avatar
dubs'se
New Member
Default engine vibration
Hey fella's, i just bought a 06 magnum se with 85k miles on it and between 30-45 mph i get a weird vibration from the engine. Its not a constant vibration but it comes and goes during accelaration. Do anyone have an idea on what could be the cause of that?
Old Nov 11, 2011 | 11:51 PM
steak59's Avatar
steak59
Does it shake the steering wheel or the whole car?
Few things to check is Tire Balance and Trans mount, motor mount.
Old Nov 15, 2011 | 02:46 PM
dubs'se's Avatar
dubs'se
New Member
Nah the steering wheel doesnt shake so its not the balance on the front wheels. yea it shakes the car..like the dash and front seats a lil..I'll check the mounts and if its them then im thinking maybe it could be misfiring..
Old Nov 22, 2011 | 05:05 PM
fireman2118's Avatar
fireman2118
This might be a long shot, but you might look into it.
I had a vibration, the same as yours in my magnum (Hemi). It turns out that the timing chain tensioner was broken causing a "loose" timing chain. This caused my engine/whole car to vibrate on acceleration. Like yours, it came and went.
I don't know if your V6 has a belt or chain. Either way it may be stretched or loose. It's pretty simple to have the timing cover pulled for a look-see.
Good luck.
