356magnum and stereo gurus
Old Aug 20, 2005 | 02:15 AM
undropped's Avatar
undropped
Default RE: 356magnum and stereo gurus
any shop should be able to do the install, the trim kit is the same as that for the Durango, anyways good luck
Old Jan 13, 2006 | 12:11 AM
Jaime340's Avatar
Jaime340
having trouble instaling aftermarket stereo any ideas (acc) wire on harnes has no were to go
Old Jan 17, 2006 | 10:51 PM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: Jaime340
what I did was tap off of the cig lighter. They sell wire taps at radioshack. Or do like I did and just disconnect the lighter and plug the wires in there. Of course Dodge has to make anything complicated. See if you lighter works with the ignition off (smokers package). If not not a prob. If it does, go the rear fuse block and move the cig lighter fuse(#18 i think) to the ign position. The fuse has 3 slots. The middle one will have a fuse leg in it. DO NOT USE the left over plug from the stock radio. It is for the CANBUS and can create all kinds of trouble and noise. Hope this helps!
Old Jan 17, 2006 | 10:52 PM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: Jaime340
Old Jan 23, 2006 | 05:39 AM
Jaime340's Avatar
Jaime340
hey guys, im thinking about instaling a kicker L5 solobaric 15 inch woofer and run my fosgate punch 800a2. for my bass. question, if i build the box under the cargo area and have the top board over it will it still sound ok.will a sealed box be ok for that sub. over all will this set up sound good. the sub facing up will i lose bass?
finaly dose anyone know were the stock amp is on the 6 speaker system?
sorry 4 all the questions, but any info will help tramendasly.
also, any other ideas or sugestions 4 me?
thanx jaime340
Old Jan 23, 2006 | 11:00 PM
356MAGNUM's Avatar
356MAGNUM
Here is the system that I started out with. The up facing subs would reflect off of the glass. Sounded damn good, but I got hooked on db drag racing, and wound up with the latest incarnation(on website). When I hauled stuff, I would put on some kicker grills that allows for full excursion. The problem with using a 15" is that it has 8 1/2 mounting depth. If you take out the fiberglass tray in the back and mount a box, 7" is the max box hieght that you can do because of the hatch latch. I had to make a slant box for the Treo that I am using because of the need for a larger box since its ported. (7"rear(11"front))X39"wX19"d. The 15" requires 1.5ft3 of internal baox space. Now if you take out the spare, you can mount a deeper box on the driver side and mount the amp(s) on the passengerside. Trim down the trifold cover and you can still use it for storage. If you are looking for SPL 3.0ft3 is the min for a ported box with 6.0ft3 for VentedSPL/DeepBass (MaximumEnclosureVolume). The 3.0ft3 might be able to do, but the 6.0 is not an option for the way you want to set up your system. I also included a pic for the stock amp location. Here is the link to the L5 Owners Manual with all the specs.
[IMG]local://upfiles/2144/8D441730B73E4780B00FD91352E92535.jpg[/IMG]
[IMG]local://upfiles/2144/1520C09ECFA5407087D50C1F09218131.jpg[/IMG]
