Magum Dub Edition 1:24
I have 6 of these in black and 6 in red...anyone wanna buy some?
http://diecastfast.com/Merchant2/mer...roduct_Count=2
http://diecastfast.com/Merchant2/mer...roduct_Count=3
ORIGINAL: strippedhemi
Heres my collection so far 3, 1/24 scale, 1/43 promo, 1/64 keychain. I painted the 1/24 to match mine, bought the same wheels on another vehicle.
Yes, its the 'Dub' model with the ghetto sound stuff out, and replaced the wheels with ones like my real one (found on another diecast 1/24 Ford custom pickup truck). the wheels are just pressed onto a steel axle. You just pull until they pop off. I had to use one of the axles from the truck, and had to remove the front brake calipers for them to fit. You might get by just grinding or trimming on the calipers depending on what wheels you want to put on.
for anyone modifying theres. Remove chassis with 6 small phillips screws. Interior floor with seating is spot glued and is easily popped out. All 4 door panels are spot glued on little pegs in the body and also pop off easily. The front and rear bumpers will slip off after you remove the chassis. Use a razor knife to pop the bottom edges of the tail and head lights from 2 tiny glue spots and pull forward or rearward to slide them out. Head lights are silver with a clear cover that all come off. Tail lights are the same except theyre dark tinted instead of clear. Dash comes out with 2 small phillips screws. Doors can be removed, but the screw holding each goes thru the hinge and has a special washer shaped head (I left my doors and hatch on). The windows seem to be attached pretty well, so I just masked them with fine line masking tape. I used liquid mask from hobby shop and a small brush to mask off the emblems and grill. After spraying you just peel it off.
