Engine Swap Help (Info Needed!)
Old May 13, 2012 | 03:00 AM
MattyR's Avatar
MattyR
Post Engine Swap Help (Info Needed!)
Hello,
I currently have a 2005 Dodge Magnum RT (5.7L Motor) with 400,00km on the engine ..
I'm looking to swap out the engine, and have a 2005 Dodge Truck 5.7L Motor I am looking to put into my Magnum (..hopefully).
Is this possible? If so, what are the differences between the two motors and what will I need to change? (per say, if they are sitting side-by-side each other).
Any info will be appreciated (:
Old May 13, 2012 | 07:57 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Check over in the Charger section. Someone just did this and he will be able to tell you. The thread doesn't give that much info but you will be able to chat back and forth to get everything you need hopefully.
Also, I would like to ask you if you do, do this project can you get some pics and write up some details as I would like to have this posted as a DIY thread for others. I think this is going to be a common thing now the engines are coming up in years and mileage.
