check egine light ???? -- 2 times
Old Aug 29, 2005 | 04:49 PM
edt00's Avatar
edt00
Default check egine light ???? -- 2 times
I have had the check engine light come on two time now. The first time was after using ¼ tank of gas then at ½ a tank I filled up with gas and the light when out the next time a drove the car. Then the light came on again at ¼ tank used and at about ½ a tank I filled up again and the light was out the next time I used the car. Has anyone had this problem? I didn’t think it is bad gas, it only came on after ¼ tank used and the gas was form to different gas stations.
2005 RT
Old Aug 29, 2005 | 05:37 PM
FlatEric's Avatar
FlatEric
Default RE: check egine light ???? -- 2 times
I think you should have the dealer hook up to it and read what the error was, could be something as simple as a bad gasket on the gas tank lid. I have not had this on my Magnum, but it happened several times on my Passat, each time it was something in the fuel pressure system.
