rain leak
Old Jan 14, 2013 | 07:57 PM
teatowej's Avatar
teatowej
Default rain leak
Hello All. I have a rain water leak when park on a hill facing down. The water pools on the driver side floor. I have an 07 magnum. I'm new to the forum world but, I did a search and it brought back a real broad amount of info. Thanks in advance for any help before I have to take her to the dealer.
Old Jan 15, 2013 | 10:11 AM
DodgeCares's Avatar
DodgeCares
Tea,
Found this TSB that may apply to the problem you are experiencing. If you need a picture PM me your an email address and I will send you one.
NUMBER: 23-005-07
GROUP: Body
DATE: February 2, 2007
SUBJECT:
"A" Pillar Water Leak
OVERVIEW:
This bulletin involves sealing body seams in the cowl area.
MODELS:
2006 -2007 (LX) 300 / Charger / Magnum
SYMPTOM/CONDITION:
A customer may experience wet carpet in the front drivers or passenger floor area.
REPAIR PROCEDURE:
1. Remove the windshield wiper arms.
2. Remove the plastic cowl cover.
3. Disconnect the wiper Motor electrical connector.
4. Remove the wiper module
5. Remove the wiper module mounting bracket.
6. Inspect the cowl seams. If any excessive sealer is protruding from this
seam, remove it.
7. Clean the area around the seam with an appropriate solvent to allow the new sealer to
bond.
8. Apply body seam sealer to the seam making sure to cover any sealer gaps that are
present. Seal both the horizontal and vertical seams
9. Install the wiper module mounting bracket.
10. Install the wiper module.
11. Connect the wiper Motor electrical connector
12. Install the cowl cover.
13. Install the wiper arms.
Old Jan 17, 2013 | 05:46 PM
Ramdit's Avatar
Ramdit
do you have a sunroof?
