P0128 and P0441
Old Apr 6, 2013 | 11:27 AM
willwells41's Avatar
willwells41
Default P0128 and P0441
Hi out there. Can anyone help with the two codes? I have a 2005 magnum with a 3.5 L. And more recently the wife says the electronic throttle control light comes on. Please help
Old Apr 9, 2013 | 10:29 PM
steak59's Avatar
steak59
P0128 is Thermostat Rationality. And that code can trigger ETC light. You should start by replacing the T-Stat and housing, and coolant. AND GET YOU PARTS FROM DEALER!!!! there are revised part for this issue.
The P0441 is EVAP performance. It is a Emission code, doesn't really hurt anything. However, it will most likely needs to be smoke tested for gas vapor leak.
Old Apr 16, 2013 | 07:44 AM
willwells41
Thanx, steak59 - I will replace the t-stat with dealer parts.
