Not shifting
Old May 19, 2013 | 10:33 PM
ralley06's Avatar
ralley06
Default Not shifting
I have an 06 magnum 5.7L taht the check engine light, ABS light, Security warning light (flashing), ESP light and the parking brake light are all on. Car will shift into drive and reverse but very hard and will not shift from first gear while driving. Hook scanner into vehicle and unable to clear codes set. Most are set for lost cummunication with ABS module. Any sugestions?
Old Jun 2, 2013 | 08:16 PM
go-part's Avatar
go-part
Former Vendor
http://www.custommagnums.com/forums/...-question.html
Old Jun 3, 2013 | 04:53 PM
NamJock's Avatar
NamJock
Shifter is plastic and junk. Mine got stuck in the Costco Tire Bay, Chrysler had it towed (literally) across the street to dealer, then, because I asked nicely - and there was another Maggie there for the same problem - Chrysler covered a lot of the repair cost. The lights are there for a reason, have the dealer fix that while you're there. You can also search the forum using key words, this has happened to a lot of us.
