Fuel Filter
Old Nov 2, 2005 | 02:26 AM
theoppositeofsuicide's Avatar
Default Fuel Filter
This is probably a dumb question but where is the fuel filter on the magnum? Is it easy to change out and is it just like changing an oil filter? Any help would be appreciated. Thanks.
Old Nov 2, 2005 | 01:16 PM
MagnumRT's Avatar
MagnumRT
Default RE: Fuel Filter
Most cars have the fuel filter mounted under the car and in the rear. Usually mounted on the frame or subframe. Not easy to get to as it does not need to be changed all that often.
Bob
Old Nov 12, 2005 | 09:47 PM
356MAGNUM's Avatar
356MAGNUM
From the LX Service manual.
The in-tank fuel pump module contains the fuel pump. The pump is serviced as part of the fuel pump module. Refer
to Fuel Pump Module.
The fuel filter is replaceable only as part of the fuel pump module.
