2005 Magnum R/T Shakes at 45mph when Braking
Old Jan 2, 2016 | 11:08 PM
CodyRachal's Avatar
CodyRachal
Question 2005 Magnum R/T Shakes at 45mph when Braking
I've read about 1,000,000,000 posts about this and cannot find anything different...
My car steering wheel shakes when I brake at 45-50mph.
I have replaced:
Rotors
Pads
Inner tie rods
Outer tie rods
Rack and Pinion
With the car jacked up I shook the wheels and I have no excess movement. None of the suspension components look worn. I had the tires balanced and alignment done but nothing helps.
Any other options of what it could be????
Next I'm going to replace the struts just in case.
Old Jan 6, 2016 | 12:17 PM
smokesxt's Avatar
smokesxt
Possible to have gotten rotors that weren't flat. Meaning you have a warped rotor.
Could have a tire that is slightly out of balance, only causing issue when extra load is applied through braking.
Wheel bearing could also cause this when the added load of braking is applied.
Old Jun 30, 2016 | 07:41 PM
soar_dude's Avatar
soar_dude
Check your tires I had the same problem when I did my front brakes. Bought new tires and the issue disappeared.
Soar dude
I have replaced:
Rotors
Pads
Inner tie rods
Outer tie rods
Rack and Pinion
Old Jan 1, 2017 | 05:22 PM
Hemibuck's Avatar
Hemibuck
Check the tire balance
Old Jan 4, 2017 | 01:24 AM
schenk2826's Avatar
schenk2826
I kept having this same issue. I would change out pads/rotors and in a couple of months I would get this shaking when slowing down. Had the front end gone through, all tight, tires balanced and alignment.
Changed pads/rotors, it went away. Then it would come back. Change pads/rotors, goes away. I have the pricey lifetime warranty rotors/pads, so now it just costs me the inconvenience of having to change them out once a year.
I have come to the conclusion the front end braking/suspension system in the magnums is craptastic. Really like the car except the front end suspension. Seemed front end problems plagued (and still do, lucky us) the magnums and early chargers. The rotors look like they belong on a truck and maybe the suspension is just not designed well or heavy enough for as heavy a car as the magnum is, not sure. But, I do know the front end is annoying on them. Good luck.
Old Jan 4, 2017 | 07:12 AM
smokesxt's Avatar
smokesxt
Next time you do brakes try some of these http://www.cquence.net/dodge-magnum-...FQMaaQod0icPfg
My 06 Stratus had the same issue for about 1yr, every 3 months I was replacing rotors. I changed out to drilled/slotted rotors, never had another problem for the next 5yrs of ownership.
Replacement rotors are junk, regardless of price, regardless of manufacturer.
