Only on fill up
Old Nov 20, 2016 | 01:09 PM
Celldoc's Avatar
Celldoc
Default Only on fill up
Why is it my 2006 Magnum R/T 5.7 Hemi will try to run out of gas within minutes after fill up? This is the ONLY time it will do this and has done it with every fill up for the last year. I can stop at about 3/4 tank and this won't happen.
Old Nov 23, 2016 | 05:54 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
SUBJECT:
Engine Stall Immediately Following Fuel Tank Fill-Up (X53 Lifetime Warranty Extension)
OVERVIEW:
This bulletin involves replacing the fuel tank with a revised part.
MODELS:
2005 - 2006 LX 300/Charger/Magnum
NOTE: This bulletin applies to vehicles equipped with a 19 gallon fuel tank (sales
code NFK).
SYMPTOM/CONDITION:
Some customers may experience an engine stall condition just after filling the fuel tank.
The integral mulit-functional control valve may allow liquid fuel to enter the evaporative
emissions system causing a rich fuel condition when the purge system is initiated..
DIAGNOSIS:
If the customer describes the symptom/condition, perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 CNSTX531AA Tank, Fuel
1 CNSTX532AA Package, O-Ring & Fastener
REPAIR PROCEDURE:
1. Replace the fuel tank. Refer to the detailed removal and installation procedure
available in DealerCONNECT> Service> TechCONNECT> Service Info> 14 - Fuel
System> Fuel Delivery> Fuel Tank> Removal/ Installation.
POLICY:
Reimbursable within the provisions of the warranty.
NOTE: Vehicles included in this Service Bulletin have a lifetime warranty for this
repair. See Warranty Bulletin; U.S. D-14-05, Canada SAB 2014-08, Mexico
BG-06-14 or International ID-14-01 for details associated with the extended
warranty.
Old Nov 24, 2016 | 11:27 AM
Celldoc's Avatar
Celldoc
Default Thank you!
It's good to know this will be a warrantied service. Thank you for the reply.
