wheel bearings
Old Mar 10, 2017 | 08:10 AM
wyld's Avatar
wyld
Default wheel bearings
are the front wheel bearings pressed in or bolt in on 2006 magnum rear wheel drive? i am askin bout the front
Old Mar 10, 2017 | 08:33 AM
They are pressed into the hub. But you need to buy the whole hub. Also replace the spindle nut. Don't re-use the old one.
Old Mar 10, 2017 | 08:35 AM
wyld's Avatar
wyld
so i if i buy the whole hub assembly it bolts in?
Old Mar 10, 2017 | 08:44 AM
Yes. Remove the wheel, brake caliper, bearing dust cap, unbolt the spindle nut, remove the hub, reverse to install the new one.
