No power on aftermarket radio install
Old Mar 20, 2017 | 06:22 PM
Ryan Iamrchris Christian's Avatar
Default No power on aftermarket radio install
I have an 06 Magnum and I installed an aftermarket radio with harness and once I was done turned on the car and the radio gets no power whatsoever. Did a little research to see if I may have an amp I don't know about and found out that if I did it would be under the steering column. Is there anyway to bypass or get the harness I need?
Old Mar 20, 2017 | 06:33 PM
Default Correction....
I don't have a factory amp....
Old Mar 22, 2017 | 03:17 PM
Check on crutchfield.com to see what harnesses you need.
