08 2.7L V6 Magnum reverse light fuse location?
When ever I turn on my lights, even if I’m in park or Drive (anything other than reverse) my passenger side reverse light stays on no matter what. I figured I’d check the fuses first. Any tips at all will be greatly appreciated, Thank you!
The fuse box is under the dash board, either driver or passenger side. your owners manual will show you and also have a listing of the fuses. Since the light works, it's highly doubtful a fuse has anything to do with your issue.
