So where is the factory amp!!
Old Mar 18, 2018 | 05:37 PM
bigaz's Avatar
bigaz
New Member
Unhappy So where is the factory amp!!
I'm new to this forum. I've had my 2005 Magnum since 2012 and just now discovered this place!!! Anyway I'm replacing the stock deck (yep the one with a tape deck). I had the choice of using the factory amp or bypassing it. I chose to bypass.
But now I can't find it!! I was told is under the drivers side kick panel. Next to the emergency brake? Ummm someone got a picture? Cause I can't find her. I'm assuming I just don't know what I'm looking for
Old Mar 19, 2018 | 10:07 AM
HemiLonestar's Avatar
HemiLonestar
Have to pull the panel below the steering column, if you have one it's right next to the TCM there.
Old Mar 20, 2018 | 09:41 AM
bigaz's Avatar
bigaz
New Member
I did pull that panel. TCM? I was told it's next to to the emergency brake. I've looked and looked...no joy
Old Mar 20, 2018 | 10:50 AM
HemiLonestar
Transmission Control Module. Like I said, IF you have one that's where it is.
Old Mar 20, 2018 | 09:22 PM
bigaz's Avatar
bigaz
New Member
Thank you friend! I for sure don't have one.
