key fob and asd issues, 2008 Magnum sxt
Old Dec 22, 2018 | 04:44 PM
Kodiak161's Avatar
Kodiak161
Default key fob and asd issues, 2008 Magnum sxt
I have a 2008 magnum sxt, the key fob does not work at all except for starting the car, when I manually unlock the car, the alarm should sound, but does not, and I have no power to the ignition side of the asd relay, therefore the car will not start, however if I jump a hot wire to the ignition side of the relay the car starts and runs fine, any help on this issue would be greatly appreciated.
Old Dec 23, 2018 | 04:51 PM
First you say the FOB will not work at all except to start the car. Then you say the car will not start. Need to be a little clearer. Did this just start happening? Have you replaced the FOB battery? Do you have another FOB. Does it have a push button start or use a key?
Old Dec 24, 2018 | 06:16 PM
Kodiak161's Avatar
Kodiak161
I was clear, fob only starts the car, and car only starts when I have a jumper wire on the asd relay, taking it in for the win module recall next week, hoping that solves my problem
Old Dec 25, 2018 | 11:45 AM
Good luck. And apparently not clear enough for me.
