07 Magnum 3.5 keep overheating
Old May 5, 2019 | 08:00 PM
Fella's Avatar
Fella
Default 07 Magnum 3.5 keep overheating
I have changed the thermostat, water pump, radiator and timing belt and my car still overheats. I can drive about 10 miles then it overheats. Anyone got any ideas what I should do next or need to do. Any help is appreciated..... Thanks
Old May 6, 2019 | 09:14 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Why did you change the timing belt in response to overheating? Are the electric fans coming on?
Old May 6, 2019 | 09:44 AM
Fella's Avatar
Fella
It ran the water pump and since I changed the water pump, might as well change the timing belt since it was there and accessible.
Old May 7, 2019 | 11:49 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Makes sense, you must've missed the fan question. Are the electric fans coming on?
Old May 7, 2019 | 11:52 AM
Fella's Avatar
Fella
Yes the fans kicked in and are working well
Old May 8, 2019 | 11:36 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
I know you said you replaced the thermostat, have you tested any of them to be sure? Sometimes you get a defective one from the factory. They may be kicking on but it doesn't sound like they are working well lol. Hoses aren't clogged or anything? I wonder if your water pump pulley is spinning independent of the impeller...
