Dodge Magnum RT 2005, Dually conversion.
Old Nov 13, 2019 | 03:35 PM
Matthew S's Avatar
Matthew S
Default Dodge Magnum RT 2005, Dually conversion.
Hi, I was reading online that there are adapters for trucks that make it in to a dually wheel set up, I have been reading in to it a little, and I was thinking, is it possible for this to work in the same way as Dodge Magnum hemi, any guidance or input would be appreciated, I was thinking of getting my MDS Turned off for a better ride as well to help push those wheels.
Old Nov 14, 2019 | 10:57 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Soooooo......what is the point of doing this? No one makes that for an LX, because 1) it's not a truck, 2) it has an independent rear & 3) the wheel wells aren't big enough. You can turn the MDS off, however MDS has absolutely NOTHING to do with the ride nor getting the vehicle moving. MDS shuts off half the engine at cruising speeds when pedal pressure and engine load are steady. The PCM turns it off if any of the variables change (pedal position, engine load, speed change, etc).
