2006 Magnum, aftermarket stereo, no sound. no amp to be found
Old Mar 11, 2020 | 10:23 AM
Jason Eden's Avatar
Jason Eden
Default 2006 Magnum, aftermarket stereo, no sound. no amp to be found
Please help. I have a 06 Magnum. 4 speaker system. I purchased new system. Now there is no sound. I cannot find an amp anywhere and not in the location under the steering wheel. Any advice would help me out. Thanks
Old Mar 11, 2020 | 12:43 PM
Little more detail would be helpful. Did it work before? Are you sure it has an amp? Did you use wiring harness adapters or hardwire? What "system" did you buy?
Old Mar 11, 2020 | 01:04 PM
Jason Eden's Avatar
Jason Eden
Yes the factory stereo will play through the speakers. I bought a harness and wired it to the head unit ( Duel, double din). There is no Amp under the dash where it should be. I just assumed it may be elsewhere because of the similar sound issues I've seen online.
Old Mar 11, 2020 | 01:37 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
If you only have four speakers then you have the base sound system and you won't have an amp (as evidenced by the fact that you don't have one). If the original works but your aftermarket one does not, I submit that you wired it up wrong.
Old Mar 11, 2020 | 01:59 PM
Jason Eden's Avatar
Jason Eden
I've installed quite a few stereo's, it's wired the way asthe instructions said. I'll go through it again just to be sure. I tapped into the cigarette lighter for power and the unit comes on. Is there anything else that I can look at?
Old Mar 11, 2020 | 02:00 PM
Jason Eden's Avatar
Jason Eden
Old Oct 27, 2022 | 07:37 PM
Adam6's Avatar
Adam6
Default Aftermarket radio no sound and no amp
Did u ever figure out the wiring
im having the same issue
