Crank but no start
Old Aug 20, 2020 | 10:20 AM
Edd Saucedo's Avatar
Edd Saucedo
Default Crank but no start
Crank no start issues... had water pump replaced a month prior to problems. Jus stopped at a
stop sign and wouldn’t turn back on. I have crank but no start. I hear the fuel pump turn on. I’m goin crazy tryna figure it out!!
Old Aug 20, 2020 | 12:47 PM
Check fuel pressure, check for spark.
Old Aug 20, 2020 | 01:03 PM
Edd Saucedo
I’m getting no spark at either coil
Old Sep 21, 2020 | 08:55 PM
JLarge's Avatar
JLarge
I would check the camshaft position sensor. It will eventually pop a code, but symptoms of it failing (like cranking but not starting) will appear before the code does.
