filling cooling system
Old Oct 25, 2023 | 07:03 PM
MrNick's Avatar
MrNick
Default filling cooling system
I have a 2006 magnum rt. I am trying to fill the cooling system. You are supposed to remove a plug on the thermostat housing and replace it with a bleed valve. That plug is all messed up and I can't get it out. Any suggestions? Is there another way to fill without changing the plug to a bleed valve?
Old Oct 31, 2023 | 09:36 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Lots of thermal cycles (run to temp & cool down) combined with burping the system constantly (opening the cap on the surge tank to let the air escape). Just make sure the car has had a chance to cool down first before touching the cap. Top up as needed. Don't mix the different types of coolant or you're gonna have a very bad week.
Old Nov 1, 2023 | 10:16 AM
MrNick's Avatar
MrNick
I was able to use an angle drill, cut down drill bits and EZ out to get the plug out and replace with a bleed valve. What a job.
