THE MOUSE GOT MY WIRES
WARNING TO EVERYONE..WHEN I WENT TO REMOTE START MY MAGNUM TODAY (SAT) I HEARD NO CHIRPS AND CAR DIDN'T START.TRIED IT AGAIN AND NO LUCK..LIFTED HOOD TO SEE IF WIRE FROM HOOD SWITCH WAS LOOSE AND LO AND BEHOLD I SAW THE WIRE CHEWED ALL UP AND I LOOKED AROUND AND THE WIRE COMING OUT OF THE BRAKE FLUID(SMALL PLUG ON SIDE)WAS CHEWED TO THE BONE..ANOTHER WIRE ON THE PASSENGER SIDE BY FIREWALL(GREEN) WAS ALSO SHOT.I REMOVED THE INSPECTION COVER AT BASE OF WINDSHIELD AND STUCK MY HAND DOWN ALONG WHEELWELL AND UP AGAINST THE FIREWALL AND FOUND A HUGE PILE OF LEAVES AND NEST MATERIAL...HANDFULL AFTER HANDFULL I PULLED OUT AND ON THE BOTTOM OF THIS VALLEY THERE IS A HOLE I'D SAY MAYBE 3 OR 4 INCHES BY 2 WHICH I WILL PLUG UP WITH SOME WIRE MESH ALTHOUGH I KNOW THEY CAN GET IN ELSWHERE..I STARTED HER UP AND THE ENGINE LIGHT WAS ON ALONG WITH THE BRAKE LIGHT..EVERYTHING SEEMED TO WORK(BRAKELIGHTS SIGNALS RADIO ETC)UNTILL I DROVE OFF..IT WAS STUCK IN 1ST GEAR..I TAPPED THE SHIFTER AND NOTHING HAPPENED..SO I LIMPED OVER TO THE DEALER FOR THEM TO CHECK OUT ON MONDAY..IT GETS BETTER..THIS PAST THURSDAY MY CHEVY 2000 P/U WHICH THE WIFE DRIVES SAID THE TRUCK WOULD NOT REMOTE START(SHE CALLED ME AT WORK) SHE STARTED IT WITH KEY AND I TOLD HER I'D CHECK IT OUT WHEN I GOT HOME..SHE SAID IT WAS RUNNING ROUGH..I CHECKED IT OUT AND IT WAS A LIKE SHE SAID SHAKEY A LITTLE BUT THE SERVICE ENGINE LIGHT WAS ON..HAD TO BRING TO LOCAL GARAGE TO FIND OUT THAT THE LITTLE#&%$%^'S CHEWED A WIRE ON THE INJECTOR HARNESS AND $163.00 LATER I WAS ON MY WAY...JUST MY LUCK..WENT TO HOME DEPOT GOT MICE BAIT TRAPS AND MOTH ***** AND WIRE MESH TO KILL OR DETER THE LITTLE MONSTERS..I'M IN JERSEY SO IT'S BEEN COLD AND I GET HOME USUALLY ABOUT 10 OR SO EVERY NIGHT SO THEY ARE LOOKING FOR HEAT..BEEN HERE AT MY HOME 13 YEARS AND THE ONLY OTHER TIME I SAW EVIDENCE OF CRITTERS WHEN I FOUND ACORNS ON MY 75 CADDY ELDORADO MANIFOLD SOME TIME BACK..SO KEEP AN EYE ON THE DRIVERS SIDE WHEEL WELL BEFORE YOU END UP WITH A MOUSE CONDO LIKE I DID..I'LL KEEP YOU POSTED....
I have one but I'm in a ranch with no basement so you can imagine all the crap I have in there..I can barely get My Harley in and out..Planning on move to Arizona when I retire in a couple of years and 1st order of business is to make sure I have a 2 or 3 car garage..
