20" VS 22" on eibach suspention
Old Jan 23, 2006 | 12:13 AM
Jaime340's Avatar
Jaime340
Default 20" VS 22" on eibach suspention
22" might look better, but also cost more. will the rt look lowerd more with 20" than 22". or will they just look to small? and how about the ride will 22" be a ruffer ride. and how about the eibach springs i know there more popular than other brands but are they that much better?
I realize i sound like a tipicle wife with all these questions, but with help i may be cruzing in a sweet customized ride.
thanx.
jaime340
Old Jan 23, 2006 | 02:31 PM
K2's Avatar
K2
Default RE: 20" VS 22" on eibach suspention
I hope this helps ....look at the way a SRT8 looks that is what a Mag that has 20's and that is lowered 1/2" looks like......when you decide to run a 22 you change the profile of the tire to match the diameter of the original tire so that the speedo and gearing does not need to be changed ....so in actuallity the diameter of the tire has not really changed but it looks bigger because of the bigger wheel
Eibach tends to make very good quality components...yes they are a little more expensive, you are paying a bit for the name ...but then again I have never personally seen a set of Eibach springs crack as I have with some cheap brands
and when you lower the car with springs the ride does tend to get stiffer
hope that helps a bit
Old Jul 4, 2006 | 10:03 PM
dstyl3mag's Avatar
dstyl3mag
i had eibach pros on my cavy and they rode great, i love them!
