installing an amp need help
Old May 17, 2006 | 02:21 PM
jninjamaster's Avatar
jninjamaster
Default installing an amp need help
im installing an amp to the stock stereo in my magnum, i have every thing hooked up but my remote wire i know it goes in the fuse box but were and how can any one help me cause i dont have a manual to look at for my fuse box help me please
Old May 19, 2006 | 02:50 PM
customtronic's Avatar
customtronic
Default RE: installing an amp need help
One easy fix to that would be to just hook up the remote turn on wire to the ignition/12volt switched power. You can find that wire coming from the ignition switch. It is an 18 guage wire. Pink with a white stripe. Make sure you use a multimeter to check the wire before you tap into it though. You should get power when the ignition is switched on and lose power when the switch is off. I hope this helps.
