Radio static
Old Jun 12, 2006 | 11:55 AM
Silver bullit's Avatar
Silver bullit
Default Radio static
Has any one had radion static after sub install. Its just a fupa i hope. I installed the OEM sub and for some reason sense then my radio plays like crap.
Old Jun 12, 2006 | 12:06 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: Radio static
ORIGINAL: Silver bullit
Could be you have a wire crossed or touching somewhere. I also know that if your audio cables are running too close to a power line...you will generate static. I'd suggest adjusting some cables and rechecking all of your connections for a good solid fit. There is also the possibility that you may need to adjust some settings on the radio and/or have a bad connection.
Old Jun 15, 2006 | 05:33 PM
Silver bullit
All i did was install the factory sub box and thats it. I ran the wires per the diagram. Then static. I will recheck them again. Thanks
