Question for Magmania
Old Aug 8, 2006 | 10:47 PM
HemiNuts's Avatar
HemiNuts
Default Question for Magmania
Has anyone else had a problem with their headlights fogging up? I thought I had it cleared up but after driving in a heavy rain one of the headlights fogged up again. I want to ask, any of you that installed the Viper Hood, did you re-install your hoods heat shield? I have not and I am wondering if that is why I am having this problem. Is it possible because I don't have the shield installed, could the heat be getting behind the light and the cool rain (or sprinkler ) causing it to fog up! Do you have a snapshot of the underside of your hood? I would like to see how you install the shield and kept the scoop functional.
Old Aug 8, 2006 | 11:19 PM
Magmania's Avatar
Magmania
Default RE: Question for Magmania
My heat shield is installed. The body shop that did the hood put my original back on. I then took a razor and cut out around the scoop outlet.
Are your lights fogging up on the inside or outside? If its internal there must be a crack or hole somewhere on the light housing. Sounds like it's probably condensation on the inside of the light. I would just replace the light (which probably costs an arm and a leg).
Old Aug 9, 2006 | 12:18 AM
HemiNuts's Avatar
HemiNuts
Yes it's on the inside. I didn't have the problem until I installed the hood. I don't see any visible cracks or hole. I hear they are expensive. I think I'll buy a new hood heat shield and see if that helps before buying a headlight.
