Throttle Delay on 3.5L engine
Old Aug 29, 2006 | 03:45 AM
MAP's Avatar
MAP
Default Throttle Delay on 3.5L engine
I got my 06 Magnum SXT with 3.5 L engine almost a month ago.
Is the throttle delay on the electronic throttle something I'm just going to have to get used to or am I the only one experiencing this?
The most noticeable time is from a stop right after I back up out of my driveway put it in Drive and press on the gas... I presssssss then the engine revs up. It's not linear. It's almost as if the first portion of the pedal travel is dead then suddenly the engine reacts.
After it's running it's not so bad. (or it could be that I just get used to it) But first thing in the morning is when I notice it the most.
Is this something that's normal or not?
Thanks,
MAP
Old Aug 30, 2006 | 05:15 AM
Jaime340's Avatar
Jaime340
Default RE: Throttle Delay on 3.5L engine
my rt dose the same , but when it gose im gone!
Old Aug 31, 2006 | 06:59 PM
coolchevy's Avatar
coolchevy
you can do the throttle recalibration mod like well described here in the forum. Works well for me on my SXT anytime I apply it.........
Old Sep 5, 2006 | 08:59 AM
darth blingger's Avatar
darth blingger
coolchevy:
can you point me to the "throttle recallibration mod" page? -I could not locate the info. Thanks bro.
Ryan
Old Sep 5, 2006 | 04:24 PM
MagnumSXT's Avatar
MagnumSXT
I've had this, do the following:
Pull fuses 11 and 14 from the front fuse box.
Turn key to on, wait for all chimes to stop (so you can hear chimes later in process)
turn and hold key to start postion
in about 10 seconds you'll hear a chime, 5-10 seconds more you'll hear chime #2
Turn off key
re-install fuses
You're off to the races now.
Old Sep 6, 2006 | 07:16 PM
coolchevy's Avatar
coolchevy
i did that differently like I have read here in the forum.
-switch ignition on but do not start,
-wait until all idiot lights go off,
-very quickly depress gas pedal
-count to five,
-jump off gas pedal and turn ignition key to off at same time
that didi it for me, but there are apparently many roads to Rome........
