Alignment & Tire Rotation tomorrow
Old Sep 13, 2006 | 01:38 PM
LakeErieFish's Avatar
LakeErieFish
Default Alignment & Tire Rotation tomorrow
Hello !
Just a FYI,
I have the RH pull & outside tire wear just like so many others here. It just happens to be that I'm due for the scheduled 12k maint.
So I called the dealer to schedule an appointment & asked about the relating TSB's.
The dealership told me that I needed to rotate the tires every 6k, that's why I have tire wear and tire pressure could be lower than normal.
I do check my tire pressure every 2 weeks, to maximize my fuel mileage.
Either way, I'm going to rotate the tires & have the front end computer aligned so I have a valid print-out. Call it "peace-of-mind".
$40 USD if no adjustment is needed, $60 if any adjustments are needed (I'm betting there is)
Forgot to put a positive note here: So far I have no other major complaints regarding my car, Very reliable(most important), Fun to drive, MPG are acceptable with an R/T model.
Thanks!
