Rear end
Old Oct 4, 2006 | 08:13 PM
Free_Style's Avatar
Free_Style
Default Rear end
The lube shop had to fill it up more than half way the last two oil changes. Instead of bringing it to Dodge and them just adding more fluid and sending me off I have waited until the rear end gave up. We'll it did not blow like I had expected I had stoped at a light and went to hit the gas and felt like the parking brake was on. Had it towed waiting to hear what the verdict is.
Old Oct 4, 2006 | 09:01 PM
via500's Avatar
via500
Default RE: Rear end
What an unfortunate attitude! When I found out my rear pinion seal was leaking I took it in and they replaced it and no more problem. Letting it run dry and waiting until it blows means ONE thing, now YOU are at the mercy of a dealer in that they can repair it properly. "Properly" means once repaired it won't make noise on over-run, load or float since ALL hypoid axles just love to make noise. I'd much rather have a factory set-up (with a replaced seal). Good luck!
Old Oct 6, 2006 | 12:59 PM
Free_Style's Avatar
Free_Style
They have decide to replace the guts and said I should get it back middle of next week. If it hums or makes any sound I will bring it back and if they still don't fix it I will trade it in to many small problems should have waited on the 06 models. At the time it was just too cool to pass up now I have a thing for the 07 Avalanche.
Old Oct 8, 2006 | 11:22 PM
Yates's Avatar
Yates
I agree with via 500 found my pinion seal was leaking and took it right to dodge to have them fix it. Thank God for warranty Pretty much the entire back half of the suspension had to be removed to change the seal. Proud to say no problem since.
Old Oct 9, 2006 | 03:48 PM
Abqhemi's Avatar
Abqhemi
ORIGINAL: Free_Style
cool, I love people like you. They make the rest of us look smart! haha!!!!
Old Oct 9, 2006 | 04:44 PM
Free_Style's Avatar
Free_Style
This is true. I have gone into dealership repair shops far too many times ans have come out with the same problem. This way I know somthing is actually being worked on not jsut looked at. They are also looking at the A/C and parking brake for the second time.
