Tires
Old Oct 25, 2006 | 10:20 PM
Walela1's Avatar
Walela1
Default Tires
I have seen a previous post regarding BFG 255 55/18 KDW being used on a members R/T. Any issues with clearances, any issues with rubbing or decreased turning radius? Any issues @ all? Is the diameter similar enough to OEM to avoid computer changes? I previously had considered BFG KDWS 245 55/18's. Thanks
Old Oct 25, 2006 | 10:59 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Tires
Here's something that will help you out.
Tire Calculator
Old Oct 26, 2006 | 01:37 PM
draftingmonkey's Avatar
draftingmonkey
Default RE: Tires
Just replaced the original Conti's with the BFG 245/55/18. Got tired of the squeel every time I pushed a corner. Finished a 3600 road trip from SoCal to the northwest and back. With the cruise set at 70 thru the Shastas they held the road like glue, even thru the 50 mph curves. And much quieter. Nice thing is that because they are the same diameter, the speedo runs correct. So unless you really want the wider look, IMO the 245's are just fine.
Old Nov 16, 2006 | 01:51 AM
MAGNUM555's Avatar
MAGNUM555
Default RE: Tires
Bump up to 20's SRT8 TIRES ON EBAY
