5.7 oil filter location
Old Dec 15, 2006 | 01:49 AM
Walela1's Avatar
Walela1
Default 5.7 oil filter location
I need to know where the oil filter is located on the 5.7 Hemi in the Magnum. Can't see it from above,haven't looked from underneath.
Old Dec 15, 2006 | 10:06 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: 5.7 oil filter location
You need to take off the belly pan (plastic skid plate) underneath the front of the car to access or view it. The belly pan is held on by 4 - 10mm bolts.
It's located on the engine passenger front side kinda below the alternator.
Here's a pictire.
<edit> I put that image together before coffee this morning, didn't mean to attach the oil filter to the Motor mount .
[IMG]local://upfiles/33009/BC37752D380F4BDD8163EC276487513B.jpg[/IMG]
Old Dec 15, 2006 | 09:50 PM
Walela1's Avatar
Walela1
Thanks, will use that info to good use. Did'nt think the filter was part of the motor mount.
Old Dec 16, 2006 | 12:16 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Old Dec 17, 2006 | 06:37 PM
65standard's Avatar
65standard
where was this picture when i was trying to figure out how to put the serpentine belt back on?
Old Dec 18, 2006 | 02:40 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I was also belt challenged and used that pic as reference.
