REC install help needed.
Hello all and thanks for your help..
I have an 06 Magnum with the standard radoi w?sirius and I wanted to install the REC nav radio. I know I will need the bezel but what else will I need. Will my dodge sirius box connect to the REC as well?
Is there an install guide anyone could point me to.
Thanks,
Mark
Thanks,
Mark
I recently upgraded to NAV. Remove the bezel unplug the standard and plug up in the Nav.The only qualifier is I have the streering wheel controls, but I don't think it matter if you don't, just plug and play, change the bezel and you are set.
The Nav install will work and all will be the same, however, you will also need the GPS antenna. The Sirius plugs in the same as the original radio.
REC stands for the 'make' of the Nav unit. If your sticker says REC, then you should have a Nav unit.
