BEST CAI
Old Feb 4, 2007 | 02:38 AM
Asgard_thor's Avatar
Asgard_thor
Default BEST CAI
http://estore.websitepros.com/802805/Detail.bok?no=335
that is one I am thinking about
I dont have a ton of money to spend...
will that void warrenty?
or should I go with the mopar one?
Old Feb 4, 2007 | 05:22 AM
HalsMag's Avatar
HalsMag
Default RE: BEST CAI
As a New magnum owner, I spoke with the guys at the dealership, running 5.7's, and they said the K&N drop in was the best buy for the buck. Slight increase at mid range., and fuel economy is claimed.
I tried it and noticed no difference in performance or gas milage. Don't know if the Fram air hog, which is cheaper doesn't give you about the same. Both save on replacement costs.
Browsing the boards, seems like Airhammer gives the best performance increase, which isn't much. Mostly you're buying sound with a CAI in my opinion.
The stock box is already fed from below, so it's already "cold air", but picks up heat from the engine compartment, and turbulence from the funky intake hose.
Cooler air will slightly increase the air charge, and reduce the burn time, resulting in lower NOx and just a tad more power. I think there are aftermarket intake tubes, but don't know if they work as advertised
The engine is controlled by an Air/Fuel ration controller and closed code computer hierchey, that will keep things running within a programmed ratio anyway.
That being said, we used to flip the air cleaner cover on our 4 barrel carbs, and they sure sounded like we were going faster when the secondaries kicked in. Just didn't prove to be true at the track.
I ordered a "sound system" and don't expect much more than that out of it.
Of the 3 R/T's I test drove, one was a slug, one really ran well, and one was in between. I bought the tweener for color choice. It's quick enough to break numerous traffic laws.
Old Feb 5, 2007 | 04:13 PM
Asgard_thor
i argee
anyone else going to reply
Old Feb 5, 2007 | 08:09 PM
2005 Magnum R/T Hemi's Avatar
I liked the one that you just tossed in the Washer and Dryer to Clean... No oils... However, unless you 'Tune' the computer in your car, you will result right back to 345 HP in a matter of time. The computer will recognize the increase and then retard your performance to get back within Specs... This goes for all Mods. Exhaust, CAI, etc...
Old Mar 11, 2007 | 12:58 AM
jljbtm's Avatar
jljbtm
Someone please tell me what a CAI is ? I read that alot here and have not decifered it !
Old Mar 11, 2007 | 03:15 AM
65standard's Avatar
65standard
CAI====> cold air intake. basically it is the air filter and the tube used to connect to the throttle body.
i think the AFE stage II is the best. larger intake tube and larger filter than the K&N setup.
http://www.afefilters.com/gendesc.php?partno=54-10712
Old Mar 11, 2007 | 10:02 PM
kcarlson's Avatar
kcarlson
I GOT THE MOPAR ONE A MONTH AGO AND HELL ITS MADE A BIG DIFFERENCE IN TAKE OFF AND PASSING.IT ALSO GROWLS WHEN U GET UP ON IT.
STRIPPER PERFORMANCE IS WHERE I GOT MINEASGARD THOR.YOU CAN BID ON THEM THER I GOT MINE FOR 200$$
Old Mar 12, 2007 | 02:05 AM
TurboDunn's Avatar
TurboDunn
I have a K&N. Won't void warranty. Its the same picture as mine but mine had a different product #. I believe it was in the 57 series. I called K&N about the one you looked at and they told me it was for the 6.1L not the 5.7 . Im not sure if there is any real difference but I ordered the one K&N told me was for the 5.7
