airbags light
Old Feb 14, 2007 | 05:17 AM
dodgestealth's Avatar
dodgestealth
Default airbags light
hello
i have always my airbags light on, i have going to my dodge dealer and tey don't know where is the problem,
what is the solution to do off this stupid light, can i disconnect a module, if yes where it is?
very thanks for your help...
Old Feb 14, 2007 | 04:19 PM
coolchevy's Avatar
coolchevy
Default RE: airbags light
in my car I try to wiggle the steering wheel and do not pull it out all the way. If I do pull it out all the light goeson, if I push it back a little it stays off......shabby craftmanship should not happen
Old Feb 14, 2007 | 05:10 PM
dodgestealth
i think is not the same problem, have you got a solution to have the light off
Old Feb 14, 2007 | 05:42 PM
coolchevy's Avatar
coolchevy
it can't be just turned off, if a failure exists in the system the lamp will come on no matter what. I would have it scanned to see what the alarm means and where it comes from. If no alarm visible then it is a wirin issue and most probably a connector pin came loose somewhere. That system is pretty well self contained and self-checking for failure
Old Feb 18, 2007 | 10:00 PM
MAGNUM555's Avatar
MAGNUM555
Since day one my passenger airbag light has come on. No ryme or reason. The orange lights turns on for days at a time and then turns off for days at a time. I should have it checked out but I have been lazy I guess.
