Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
I need help identifying my Automatic Transmission
Old Mar 30, 2007 | 05:10 PM
1974DodgeCharger_SE's Avatar
1974DodgeCharger_SE
Default I need help identifying my Automatic Transmission
Hey guys, I was wondering if there is an easy way to determine what kind of transmission my car has.
Itsa 1974 Dodge Charger SE which use to have a 318 V8 and now its being upgraded to a 360 V8.
I am trying to determine if its an A727, A904, A998
Any help would greatly be appreciated. I also tried running the Fender Tag code for the Transmission with little to no success in trying to determine my transmission. The transmission code on the fender tag is D34 if that helps.
Thanks guys.
jason
Old Mar 31, 2007 | 02:18 PM
mr340's Avatar
mr340
Muscle Car Moderator
Default RE: I need help identifying my Automatic Transmission
D34 is the A904 transmission.
Old May 25, 2007 | 02:34 AM
draftingmonkey's Avatar
draftingmonkey
Jason, Post a pic. I have a '74 Charger myself (not an SE though). Should be able to see my photo in my gallery. Mr340 is correct BTW.
Old Jun 5, 2007 | 12:19 PM
ucfierocharger's Avatar
ucfierocharger
I have a 73 Charger and on the transmission case it says A-727, you could probably start there.
And I believe (although there are a TON of people that know more than me about the trannys and if im wrong im sure they will chime in to correct me) that where the dipstick tube goes into the transmission is an easy way to identify it from the top.
Although I dont really know how to describe the physical characteristics. After looking online for some pictures, I failed, but i did find pictures of the boltpatterns of the 727 and the 904
<--727 <--904
I know its a little late, but hope it helps (im working on my own transmission misadventure so just trying to help who i can)
Old Jun 6, 2007 | 11:19 AM
speedyshelby's Avatar
speedyshelby
http://www.carcraft.com/newlook/crc_act/116_0302_trans/
