Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
318 rebuild
Old May 11, 2007 | 06:02 PM
D100318's Avatar
D100318
Default 318 rebuild
I have a 69 Dodge D100. I need to rebuild the 318 that is in it. Does anyone know of anything I can do to soup it up a little while i'm in there?
Old May 21, 2007 | 12:46 AM
dartboy's Avatar
dartboy
Default RE: 318 rebuild
There are lots of things that you can do while you are in there. Camshaft, heads, intake, carb.... The most bang for your buck would be a camshaft. Not too aggressive if that is not what you are looking for but a couple bumps up from stock. That stock camshaft is very small.
Old May 25, 2007 | 02:26 AM
draftingmonkey's Avatar
draftingmonkey
Check out the June issue of Mopar Muscle. They just did an article on a 318 rebuild. May give you some good ideas.
Old Aug 17, 2007 | 12:40 PM
mikey CMX's Avatar
mikey CMX
How do I get the dust cover off the bellhousing to loosen the flywheel/torque converter bolts?
Old Dec 12, 2007 | 10:17 PM
dodgebrothers's Avatar
dodgebrothers
Headers and dual exhaust as well as four barrell will do wonders for it, especially with the camshaft upgrade already mentioned.
Old Jul 9, 2008 | 01:53 AM
bigbrian1980's Avatar
bigbrian1980
Junior Member
yeah nothing beats mopar
Old Jul 23, 2008 | 11:56 PM
baracis's Avatar
baracis
Hopefully this will help someone:
Hot Rod Magazine: Junkyard 318 Rebuild
