Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
question about 3:55 gears
Old Aug 12, 2004 | 10:49 PM
skoozie4406pk's Avatar
skoozie4406pk
Default question about 3:55 gears
i currently have 3:55 gears in my 71 challenger 440 6 pk auto. i am running at 3000 rpm's at 60 mph. that seems a little high to me. i am thing about either getting 3:23? gears or possibly getting larger tires. i am running the stock tire now (235 60 14's)
i was looking at getting some american racing rims, torq thrust d's, to be spacific. but not sure what sizes to get i want to switch to a 15" rim though would also like to have the tire wider in the back?
also what is my max rpm range for a 440
lots of questions i know, but i am quite green to this whole car thing. i bought the car 2 years ago when i was 22 and didn't have much time or money to work on it. now i'd like to get it fixed up so i can actually enjoy it. it surely is an eye catcher!!!
Old Aug 13, 2004 | 01:33 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: question about 3:55 gears
well, when i had my 4:88s in my mirada, at 60mph i was around 5000rpm on the highway! i can see if i have some 3:23s laying around..
also, if that is your exact tire size, your tires are only about 25.1 inches tall. my dot slicks are 26, and it is my understand that gear ratio is calculated with a 26" (or so) tall tire, so youre actually a bit steeper than 3:55.
Old Aug 13, 2004 | 06:25 AM
71RoadRunner's Avatar
71RoadRunner
For the info you need on changing wheel and tire sizes, go here: http://www.tirerack.com/about/techcenter.html
For the info on your engines max RPM range as well as tons of other info on your car and all other Mopars: http://www.allpar.com/mopar/440.html
Good luck with your upgrades.
Old Dec 10, 2004 | 03:23 PM
SKYLORDD's Avatar
SKYLORDD
I've got 275- 60- 15's on my Cuda. mine is a 340 /6pk though. they fit fine and rpms are reasonable.
[IMG]local://upfiles/9974/E0C6ED2559FA4DD3B65D015129E9A348.jpg[/IMG]
Old Dec 11, 2004 | 07:10 AM
71RoadRunner
Now that's the kind of car show I would like, Mopars galore and indoors.
Old Dec 20, 2004 | 12:08 PM
big asp's Avatar
big asp
I know I'm late to the party but if you're still interested, look into a gear vendor for your car. They attach behind you're current transmission and give you an overdrive. You'll have to have your drive shaft shortened but other than that it's a painless installation. Gear vendors are built very stout so you won't have to worry about breaking it. It won't hurt performance either. In fact, it'll give you a faster top end speed!
Also, switching to 15s and maybe going to a bigger sidewall if they'll fit will help your cruise rpms. You might even have room for a 29" or 30" tire.
Old Dec 20, 2004 | 12:10 PM
big asp's Avatar
big asp
I like your 'Runner!
Old Dec 21, 2004 | 05:43 AM
71RoadRunner
Thanks! I have seen the overdrive setup your refering to in a Mopar magazine, it gives an overdrive gear for each gear. It basically turns a 3 spd auto into a 6 sod auto and it bolts to the trannys tail shaft.
Old Dec 22, 2004 | 01:10 AM
skoozie4406pk
i wonder how much this would cost.
i recently bought some torq thrust d's ( 15"X7) i put 265 60's on the back and 225 60's on the front. i have yet to put them on yet. i'm going to wait till next year to give it a try. the roads are all full of salt around here.
who knows i might be happy with this... well at least i'll look cool!!!!!! that's right all chrome!!!!
Old Dec 26, 2004 | 01:36 PM
moparturd's Avatar
moparturd
ORIGINAL: 71RoadRunner
I remember reading that article. They were saying to shift it correctly to get the most benefit, you would have to go back and forth as you shifted. It is a slick set-up though since it bolts to the tailshaft.
