Stuck Brake
Old May 20, 2007 | 02:09 AM
fedie0007's Avatar
fedie0007
Default Stuck Brake
The rear passenger brake on my 95 neon is stuck on and I can smell the shoes burning up if I try to drive it. I have disconnected the parking brake, replaced the wheel cylinder, and bleed the brake a couple of times but cannot get the brake to relieve pressure on its own. I can relieve the pressure by using a c-clamp on the wheel cylinder, so it can go back it just won't. I am getting a little annoyed and wonder if adjusting these brakes would help or if there is a way to disconnect the brake temporaily so I can at least drive the car. Thanks for any suggestions?
Old May 21, 2007 | 11:23 PM
neisg1's Avatar
neisg1
Default RE: Stuck Brake
It sounds like the auto adjuster has over adjusted the brakes. Try backing off the adjuster screw assembly a few turns. Make sure the adjuster is clean and properly lubricated.
Old May 22, 2007 | 06:50 PM
ewetho's Avatar
ewetho
Either a frozen wheel cylinder (not expensive) or over adjusted brake.
Old May 24, 2007 | 05:02 PM
fedie0007's Avatar
fedie0007
Thanks for the help guys, it turned out to be a faulty brake hose.
