foggy headlight
remove the entire assembly from the car, dry it out then around the housing you'll see where it was put together, there will be a seam, take some RTV (clear) and go around the entire assembly. Let it cure and dry for 24 hours then reinstall. It should fix the condensation in the headlight.
well, i have my own .02 for this one. when i got my new headlights, diamond clears, i got condensation after a couple weeks or so. what i did, was waited til the hottest day of the year (or so) and took the bulbs out in the morning, then around 3 p.m. or so, put them back in. this is the best solution if your headlights don't have breather holes in them. somone will probably post with breather holes, ask them.
ive actually tried a blow dryer and that didnt seem to do anything. ive also tried to set it out in the sun, and that didnt do anything either. ugh, i think ill have to buy a new one. oh, are there any aftermarket headlights out there? i wouldnt mine droppin money on aftermarket ones, just if i had to buy stock ones itd suck lol.
