2003 Neon Battery Replacement
Old Jul 14, 2007 | 11:17 AM
AmysNeon's Avatar
AmysNeon
Default 2003 Neon Battery Replacement
Hello, I think I need to replace the original battery on my 2003 Neon. Recently the car seems to momentarilly die, then goes again.It happened 8 times in 45 minutes today. At a traffic light the engine stopped, i was able to restart the car.How do I remove the cover from the battery in order to replace it?
Thank you
Old Jul 31, 2007 | 07:48 PM
neonxst05's Avatar
neonxst05
Default RE: 2003 Neon Battery Replacement
First make sure your alternator is still working fine. If it is bad, your battery cannot maintain the demand ouput. IF your alternator is fine then I would recomend getting an Optima red top. It might be pricey, but it is well worth it. To take the stock battery out, you have to slip off the heat shield by removing the cables first, the shield will slip off up. then on the back of the battery at the bottom you will see a bolt that holds it in. If you want to save the headache, purchase a battery at a place that will give you a free install.
Old Aug 1, 2007 | 12:13 AM
RickMN's Avatar
RickMN
I doubt that your stalling problems are battery related. If the battery voltage was so low that it couldn't keep the car running, you wouldn't be able to restart it without a jump or a quick charge. Take it in and have it checked out before you start replacing things.
Old Aug 18, 2007 | 06:01 PM
Flash_Gordon2392's Avatar
Flash_Gordon2392
I was in the same boat a month ago with my battery.If I was you,I would check out your battery cables for corosion.
