Check Engine Light 2000 Neon ???
Old Oct 7, 2004 | 09:49 PM
tyson724's Avatar
tyson724
Default Check Engine Light 2000 Neon ???
I keep getting a code p0071 ?? say's Reserved for SAE ?? what is this code for ??
[IMG]local://upfiles/4785/FDA12A204FB5442C8EBA425CC355E959.jpg[/IMG]
Old Oct 7, 2004 | 11:19 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: Check Engine Light 2000 Neon ???
Probably nothing. I've got no records of it.
What other codes are you getting?
Old Oct 7, 2004 | 11:30 PM
tyson724's Avatar
tyson724
no other codes . i checked the books. i cant find anything. there must be a problem with something.
Old Oct 8, 2004 | 12:30 AM
Cr@zy Squ33
I doubt it. I'ts probably nothing more than a 12 or 55 on a 1st gen. i wouldn't worry too much about it.
Old Oct 9, 2004 | 01:25 AM
tyson724's Avatar
tyson724
i saw this on the the form. is this correct ?
P0071 Ambient Temp Sensor Performance Ambient change less than 3 degrees cel. In 200 miles
what does this mean ??
Old Oct 9, 2004 | 02:04 AM
RayDog26's Avatar
RayDog26
i never had that code so i dunno. but try clearing the computer and see if the code comes back. some times they pop up for a one time things even if there problem is gone the code stays.
Old Oct 10, 2004 | 11:19 PM
tyson724's Avatar
tyson724
it does come back 30 days later .same code
