2002 Neon ES Fog Lamp Assembly
Old Jul 16, 2007 | 07:44 PM
DeadlyDakota's Avatar
DeadlyDakota
Default 2002 Neon ES Fog Lamp Assembly
I was wondering if anyone has ever removed the entire Fog light assembly for the 2002 Neon? I have to replacethebulb and when I went to do this I noticed that the bulb was already shattered inside the fog lamp assembly. I would like to remove the assembly so that I may remove the broken glass but I cannot find any way to unscrew or unbolt the lens. Any help would be greatly appreciated. Thanks.
Old Jul 18, 2007 | 09:47 AM
dodgepartsman's Avatar
dodgepartsman
Default RE: 2002 Neon ES Fog Lamp Assembly
the lens is not available as a replaceable part, so it doesnt come off.
REMOVAL OF FOGLAMP
[ol][*]Disconnect and isolate the battery negative cable.[*]Remove nuts attaching fog lamp to fascia.[*]Disconnect wire connector from fog lamp.[*]Remove bulb from lamp. [/ol]
Just shake it out after you remove it.
Old Jul 24, 2007 | 07:17 PM
DeadlyDakota
Thanks for the tips however I cannot locate the nuts to remove the lamp. Do you have a more specific location? I appreciate all of you time in helping me out.
